Author Topic: Setting a custom namespace  (Read 16104 times)
Rob999
« on: October 06, 2015, 06:57:59 am »
We have a lot of classes already generated and the package structure does not fit the namespace requirement.  Is there a way to override the namespace (and the namespace used in Imports and Inherits) at the package or class level?  We have some reservations on creating the required packages and moving an entire tree of classes to correct the problem.  We're using VB.net, but I imagine this would be the same as C# or Java.  Thanks
Re: Setting a custom namespace
« Reply #1 on: October 06, 2015, 08:46:22 am »
No, EA uses the package structure.
Since this is the UML Process forum... In UML a Package is a Namespace.
« Last Edit: October 06, 2015, 08:48:50 am by simonm »
« Reply #2 on: October 06, 2015, 10:48:50 am »
Indeed, but EA conflates Folders with Packages...
In any browser, each folder CAN'T be a namespace - indeed, EA requires you to nominate the Namespace Root.
So Every package is a Folder, but NOT every folder is a package...
It would be good if EAUI would recognise this fact and support it properly.
« Last Edit: October 06, 2015, 10:49:46 am by PaoloFCantoni »
« Reply #3 on: October 07, 2015, 08:31:34 am »
I think you're confusing EA with UML. As I said, UML specifies that a Package is a namespace.
EA does provide more flexibility with namespaces for code generation than UML provides. 'Namespace root' means suppress namespace for this package and all parents. 'suppress namespace' was also added while you were away. It allows the namespace for a single package to be omitted from code. In your terminology it's effectively making it a folder.
However I judged that neither of those points would help Rob999.
« Reply #4 on: October 07, 2015, 11:02:01 am »
Fair enough...  I also agree that suppress namespace is useful.  I haven't used it yet, but will do in the near future.  I think I first asked for it 7 or so years ago.
