Author Topic: User interface model  (Read 21346 times)
Henrik Raböse
« on: October 21, 2015, 12:46:05 am »
i've some custom usercontrols drawn. Now i want  to insert these controls in other controls as refernce (link).
How do I do that?
Custom controls:
Usercontrol to insert custom usercontrol:
regards
Henrik
« Last Edit: October 21, 2015, 12:54:06 am by Henrik.Raboese »
Re: User interface model
« Reply #1 on: October 21, 2015, 04:02:04 am »
Select all elements of you usercontrol on the diagram and press Ctrl-c (copy)
Then go to the target diagram and press Ctrl-V (paste)
That will also copy the layout to the new diagram.
Henrik Raböse
« Reply #2 on: October 21, 2015, 06:06:50 pm »
Ok,
this make a copy of elements no reference.
« Reply #3 on: October 21, 2015, 06:30:27 pm »
Ok,
Why do you think that?
To make a copy of the elements you need to press Shift-Ctrl-V
Henrik Raböse
« Reply #4 on: October 21, 2015, 09:30:09 pm »
By Ctrl+C and Ctrl+V on the same view - the error dialog says:
"Only one instance allowed."
I do not want any instance, I want a reference! ;)
Ok my next test was:
Draw userControl on a view - and on another view in a control again via Ctrl+c ... Ctrl + v.
The result is confusing!
The usercontrols in the project tree moves from the folder to the element on the other view. Shown in the clip.
http://it-raboese.de/ea/ea.avi
« Last Edit: October 21, 2015, 09:45:31 pm by Henrik.Raboese »
« Reply #5 on: October 21, 2015, 09:49:33 pm »
You can only show one reference to an element on a single diagram (except in v 12.1, there you can somehow add multiple representations on the same element on a diagram)
Yes, the fact that your elements are being relocated can be quite confusing and annoying.
You can turn this behavior off by unchecking "Tools|Options|Objects|Support for Composite Objects", but then it will be turned off for everything.
Henrik Raböse
« Reply #6 on: October 21, 2015, 10:03:38 pm »
Ok.
Thanks.
Is v12.1 a beta release?
I don't found a download link.
regards
Henrik
« Reply #7 on: October 21, 2015, 10:22:17 pm »
Yes, 12.1 is still in beta.
Sam Courtney
« Reply #8 on: October 24, 2015, 12:52:36 am »
