Author Topic: UML Class - Notes Box  (Read 14597 times)
SilverSage
« on: November 11, 2015, 08:55:35 am »
Is there a maximum size for this field? We're having an issue with text and hyperlinks disappearing from a notes box in one of our classes.  There are a ton of hyperlinks created in this area - we had to jerry-rig a method to create a Word-based report that EA doesn't provide and can't be created through EA scripting, so a VBA for Word program was written to create what we needed and necessitated a class be created to hold hyperlinks that the VBA program reads - and I'm thinking the reason for the random link disappearances is that we're bumping up against the maximum size of this field.
Thoughts?
Thanks in advance for your help.
Re: UML Class - Notes Box
« Reply #1 on: November 11, 2015, 09:58:05 am »
Depends on the RDBMS you're using. Have a look in the CREATE script to see what size t_object.notes has. Eventually you can make it a memo field but on your own risk (memory overflow inside EA might be a side affect). I remember several threads where people asked to extend fields. Don't know what the outcome was in the single cases.
SilverSage
« Reply #2 on: November 11, 2015, 10:01:53 am »
Thanks q. Appreciate your response, as always.
