Author Topic: Bug in use case metrics reports  (Read 51820 times)
Mr. Sanders
  • Dilbert for president
« on: October 29, 2007, 12:54:00 am »
I found two bugs in the use case metrics reports.
When you generate the report you get some tables.
One of them is in the section
Environmental Complexity Factors.
The last column header int the report is called TCF!
This is wrong! it must be EF!
The second bug is the nomenclature sparx uses. It is wrong.
The use case metrics are based on Gustav Karners Use case Point method.
He introduced technical complexity factors, describing the complexity of the SW-project (TCF).
He also introduce environmental factors  (EF) and NOT environmental COMPLEXITY factors.
The environmental factors describe the poductivity of the team and has nothing to do with complexity.
Therefore the name must be EF and the column header must be EF.
Regards
Michael
sargasso
Re: Bug in use case metrics reports
« Reply #1 on: November 01, 2007, 03:53:22 am »
Google "Kirsten Ribu"'s work.  IMO, EA is more aligned with her work than Karner's.
hth
bruce
Mr. Sanders
« Reply #2 on: November 01, 2007, 10:00:52 am »
what do you mean with
hope that helps.
Sparx says it is using Karners method.
But it is not using Karners nomenclature.
This is a bug, and I hope they fix it.
Regards
Michael
