Author Topic: BUG in version control handling?  (Read 88544 times)
Mr. Sanders
  • Dilbert for president
Re: BUG in version control handling?
« Reply #15 on: December 20, 2007, 01:06:18 am »
yabajabadoo
they will fix it!
have now reproduced the behaviour you are reporting and I can confirm that the current behaviour is incorrect.
A manual XMI import of a version controlled package file, should still move aside the child packages and restore them once the import is complete.  I will implement a correction to this behaviour as soon as possible.
But I am still surprised, that 'I' wrote that bug report.
This is a real major problem! Isn't it?
Michael
Martin Terreni
  • Sorry, I can't write
« Reply #16 on: December 20, 2007, 02:39:12 am »
Good work Michael!
Recursion definition:
« Reply #17 on: December 20, 2007, 05:15:53 am »
yabajabadoo
they will fix it!
Michael
Well done Michael!
I'm not surprised. Yes, it is a major problem, if you are using VC and have your setup. But Sparx cannot repair the way EA works unless someone tells them there is a problem - and characterizes the problem in enough detail to recognize and verify that it is a problem. That's where you came into the picture.
Not everything can be noticed in testing. In situations like VC, it is easy to miss something that is configuration dependent, even to a small extent.
Thanks for seeing this through, and for taking the time to work through the bug report.
Mr. Sanders
« Reply #18 on: December 20, 2007, 05:22:19 am »
Well done Michael!
Yes, of course.
I just wonder that nobody else reacted on that problem before me.
I mean, I am not the only person using VC and EA.
And this is such a fundamental step, that anybody else should have found AND reported the problem before me.
That's what makes me wonder.
Nevertheless, they fix it.
And that's it, what counts.
Michael
