Author Topic: Note: Virtual RTF documents bug  (Read 42845 times)
Oliver F.
  • ArenĀ“t we all in the model business ?
    • Karl Storz homepage
« on: January 22, 2008, 11:32:10 pm »
Hi all.
Please note: If you are using virtual documents by dragging packages on a <<model document>> stereotyped class, it is not a good idea to edit the class attributes afterwards, especially not to edit the attribute name and alias.
It will result in the RTF generator bailing out right after the generation process has been started leaving the generated document in a structural mess.
I had a hard time finding that beast as I first blamed the template for it (because experienced usually showed that this is the correct suspect).
This bug is present until 7.0 build 818.
Sparx Systems is informed and will fix it in one of the next builds.
Oliver
