Author Topic: Can't use floating key from EA using CrossOver  (Read 21120 times)
bszmyd
« on: February 10, 2008, 03:52:33 pm »
Hello All,
I did a brief search on the forum and web and could not find any information on my issue. I am trying to use EA 7 through Wine. I have successfully installed all the components along with EA, but when it comes time to enter a license I have not be very successful.
I am using a floating license located on another machine. The first problem I have is that I can not enter the traditional "\\<machine-name>\<share-name>" path into the file browse dialog when choosing my keyfile. I tried mounting the keystore 's shared directory using samba and then accessing the key that way. I was able to see the key file under the file dialog, but just to get the error:
"Error reading Key Store File (Key file has been moved)"
...help?  ???
Aaron B
Re: Can't use floating key from EA using CrossOver
« Reply #1 on: February 10, 2008, 04:40:06 pm »
Unfortunately it is a known problem that floating licenses do not work under Linux/Crossover at this time.  There is a limitation in the WINE API that interferes with how the floating license system detects if a file has been moved from it's original location.  We are yet to find a workaround for this problem.
If you wish to exchange your floating licenses for another license type, please contact [email protected].
Any further technical questions on this issue, please contact [email protected].
