Author Topic: Length of tagged values  (Read 21828 times)
dr_shorthair
« on: February 11, 2008, 09:04:29 pm »
We want to include some (XML) implementation-specific information in a UML model (Schematron fragments) that is used by an external encoder.
The usual place to add implementation platform specific detail is in Tagged Values.
However, the length of the tagged value field appears to be limited to ~256 chars.
Is this a UML limitation, or just the EA implementation?
Can it be increased?
If not, then we will have to reconsider where to store potentially long Schematron elements.
Any suggestions? - N.B. must be consistent with UML spec, and not EA specific or a kludge.
Simon
Re: Length of tagged values
« Reply #1 on: February 11, 2008, 09:16:53 pm »
Simon,
I think if you search for "tagged values" and "memo" (within last 10 days) you should get the answer you're looking for.
dr_shorthair
« Reply #2 on: February 11, 2008, 09:44:51 pm »
Great - thats a good start. I can use this.
Is there a way to export all my UML Settings so that someone else can load them?
Simon
« Reply #3 on: February 11, 2008, 09:52:45 pm »
Depends on which settings. "Tools > Export Reference Data" and select everything is a good start. You can also run regedit and save the appropriate branch in there.
dr_shorthair
« Reply #4 on: February 11, 2008, 10:30:03 pm »
Doesn't appear to allow custom tagged-value types to be exported (as entered using the Settings/UML dialogue).
I also have an issue concerning how to harmonize the various ways to add custom tagged-value types, but probably better to start a fresh thread for that.
RoyC
  • Read The Help!
« Reply #5 on: February 12, 2008, 02:38:59 pm »
You export Tagged Value Types as Property Types. The .PDF and product Help should identify that, but the website help is still lagging behind.
Try looking for Reference Data     Export in the product Help index.
If you have already tried this, we will have to think again about the problem.
Best Regards, Roy
