Author Topic: Automatic HTML Report Generation  (Read 4588 times)
cameron
« on: October 06, 2005, 02:09:33 pm »
Greetings,
I would like to automate the generation of HTML documentation based on a particular project.  Basically, I'd like to add an option to my overnight code build that does the equivilent of Project->Documentation->HTML Report.  Is there a way to do this?
--Cam
Re: Automatic HTML Report Generation
« Reply #1 on: October 07, 2005, 03:42:13 am »
You could likely adapt the autodoc Perl script which I published here.
Jeff Odell
« Reply #2 on: October 07, 2005, 03:44:55 am »
You need to use the Automation interface.  I created a NAnt task, since I'm working primarily in the .Net space.  Depending on where you are most compfortable accessing COM objects, this is a quick task.
cameron
« Reply #3 on: October 07, 2005, 02:17:41 pm »
Thanks.  The autodoc.pl PERL script worked great and I was able to adapt it generating HTML as well.
