Author Topic: Quote in note compartment render wrongly (beta02)  (Read 19961 times)
thomas.kilian
« on: February 26, 2008, 09:02:57 pm »
The note compartment renders a quote (") as "
I suspect other chars to be render also incorrectly.
Bug submitted...
« Last Edit: February 26, 2008, 09:03:54 pm by thomas.kilian »
Re: Quote in note compartment render wrongly (beta
« Reply #1 on: February 26, 2008, 11:01:38 pm »
They did say it was 'modified' HTML...
What happens if you turn off rich text display?
thomas.kilian
« Reply #2 on: February 26, 2008, 11:42:07 pm »
Don't care. Beta01 worked. 02 didn't. Ergo: Bug.
« Reply #3 on: February 26, 2008, 11:58:54 pm »
Oh, no question about that whatsoever. I just wondered what happened?
I've tried this, both with a notes compartment and a note element. I made sure that there was rich text in both. I get the correct display with the note element, which always has rich text turned on. [The Set Feature Visibility dialog always shows it as off though, even if you change the setting and reopen the dialog.]
With a class element though, I get the correct display with rich text turned on. I get your result with rich text turned off. I do not get the problem with apostrophes, so the bug is likely isolated to specific entities, perhaps only double quotes.
« Reply #4 on: February 27, 2008, 08:56:54 am »
This effected both beta 1 and beta 2, when the element is not rendering formatted text.  The error will also effect the legacy rtf report, testing report and a few extra places under the linux build.
« Last Edit: February 27, 2008, 08:58:04 am by simonm »
thomas.kilian
« Reply #5 on: February 27, 2008, 09:42:53 am »
Which means "known and bad luck for me" or "know and will be corrected in release x"? I can not understand why it rendered correctly in Beta01 but not in 02 if, as you state, the error was also in 01. :-?
mrf
« Reply #6 on: February 27, 2008, 10:32:29 am »
I've come across many quote characters in the Unicode system, Windows seems to make different ones the default for certain locales. Is it possible that you were using a different quote character in the Beta 01 release than what you were in Beta 02? That could explain the discrepancy.
Best Regards,
Michael
« Reply #7 on: February 27, 2008, 10:36:48 am »
Known and not yet corrected, but I'll do my best to make sure 7.1 doesn't go into production with the error there.  I'll keep you posted.
« Reply #8 on: February 27, 2008, 01:14:27 pm »
Should be fixed in the next build, and probably didn't see it in beta 1 because the notes hadn't been saved for that element yet.
