Author Topic: Version 3.51 - Build 614 Released  (Read 22904 times)
sparks
« on: June 03, 2003, 11:49:11 pm »
Changes in Build 614
Elements with parent names specified graphically now resize if name is longer than class name
Fixed error with UML:Diagram XMI being written out during export when Diagrams set to non-export
Added support for C# event keyword (field declaration and accessor) to C# parser.
Added ability for ordinary user to 'View Current Locks' when security enabled. View Locks is a new Permission.
Fixed problem with Java parser misinterpreting default values of attributes when the default is a scoped name
Fixed error in automation interface which could cause Models collection to throw an exception
Change to XSD Schema generator - For complexTypes which contain an attributeGroup and are derived from another complexType by extension or restriction, the attributeGroup is placed within the extension element.
Duplicated objects now created with User Lock applied where 'Require User Lock to Edit' is enabled in security
Fixed problem in adding items to Glossary
Links page of Object Properties dialog now works with Locate Object when the target is a package type
Fixed some instances of case sensitive SQL which could cause issues on UNIX based version of MySQL
Added ability to define a default user diagram for corporate edition when security is enabled.
       User may set any diagram to be their own default
       Function is available from the diagram context menu - when user security is turned on
Made 'New' button on Requirements page of Object Properties dialog always enabled - even when a linked requirement is selected
