Author Topic: MDG Merge/Export  (Read 3441 times)
kenan820
MDG Merge/Export
« on: October 13, 2005, 09:53:40 am »
I'm trying to use MDG to forward engineer classes into VS.NET and I was wondering if there were any configuration options.  What I'm wanting to do is to set up the default filename to which the classes will be exported.
Example:
{package name}\classname.cs
so if I have, under the solution package, Package1 and the a class that I want to export under that called Class1 the default filename that would come up for the export would be: Package1\Class1.cs
Is this possible?  If not, are there plans to expand MDG to be configurable via a xml config file or something similar?  I would think that would be a good thing to do.
Kenan Dalley
Software Architect
CS*STARS
