Author Topic: Datamodel not showing up in reverse engineering  (Read 4701 times)
Sri
« on: April 10, 2008, 06:56:54 am »
Hi
We have database(around 400 tables) in SQLServer 2005 which has relations, FKs clearly defined. I have imported the schema into EnterpriseArchitect ver 7.0. But I am not able to see the datamodel diagram showing relations between the tables in datamodel window. But when I look at the properties of the tables they have Foreign Keys defined.
Is this an issue or am I missing something to show the relations between the tables and also show all the tables in the data modeling window.
Also is EA right tool for this kind of data modeling or should I use Erwin?
We want to maintain a single tool for data modeling and also for application design (in java).
Thanks in advance
Sri
shagunbidani
Re: Datamodel not showing up in reverse engineering
« Reply #1 on: July 18, 2016, 08:44:57 pm »
Hi Sri,
Were you able to solve this problem ? I am also facing similar issue and want to import everything in EA due to similar reason.
Thanks!
« Reply #2 on: July 18, 2016, 09:13:30 pm »
Your XMI issue is something different. And this post is about version 7 (we are at beta 13). Go ahead and try the import.
