Author Topic: DAO.Field[3107] message  (Read 9898 times)
sapphire
« on: April 11, 2008, 03:43:08 am »
After opening the .eap file and opening the data model, I am getting the following message.
DAO.Field[3197]
The Microsoft Jet database engine stopped the process because you and another person are attempting to change the same data at the same time.
There is an "OK" button and I click it 25 times to finally clear the message. I have 51 tables in the data model. The message appears anytime I save the file too.
I am the only user using this .eap file.
Any suggestions?
julie w
Re: DAO.Field[3107] message
« Reply #1 on: April 16, 2008, 01:08:57 am »
I'm just in the process of searching around for information on the same issue.  I don't have the answer either so not much help for you I'm afraid, but doing a google search it seems to be a common pc registry fault and I'm considering trying some cleaning utilities.  However, if anyone else has any ideas I'd be grateful...(cos I'm not that geeky!).  What I would say is that I've noticed more of these funny features having installed the latest version of EA.
julie w
« Reply #2 on: April 16, 2008, 05:26:16 pm »
Since my note yesterday I've exported all the packages within my problem model and reimported them to a new .eap file and it seems to have done the trick and solved whatever corruption was going on.  I would still like to know the underlying cause if anyone can help.
sapphire
« Reply #3 on: April 17, 2008, 12:18:01 am »
I did what you suggested in exporting the package and creating a new .eap file and then importing the model. I did not get the error message in the new .eap file. So then I exported the package from the new .eap file and imported the package into my original .eap file. I don't get the error message so I can keep the orginal .eap file. YEAH!!!  I still have not found a cause for it. thanks
julie w
« Reply #4 on: April 17, 2008, 12:21:29 am »
Good stuff.  I think it might be something to do with the .ldb file that opens up when you open up the .eap file but I don't really know.  Anyway, as long as there's a way round it for now. :)
