Author Topic: Code Generation for WSDL not compatible with Axis2 wsdl2code?  (Read 8202 times)
Randy McNob
I'm generating a WSDL from EA, and when it creates wdsl:message wsdl:part elements, it references the datatypes using a "type" element. Axis2 seems very fussy about this and insists on the attribute "element" instead.
i.e.
<wsdl:part name="Result" type="ldt:LogEntryAcknowledgement" />
has to be changed by hand to...
<wsdl:part name="Result" element="ldt:LogEntryAcknowledgement" />
...before it will work with Axis2's wsdl2code generator.
I think this may be because i'm using document literal - however, my EA model is aware of this and it is set in the generated wsdl binding.
Is there any way to get EA to output the wsdl as I want it to or am I missing the point?
thomas.kilian
Re: Code Generation for WSDL not compatible with Axis2 wsdl2code?
« Reply #1 on: April 20, 2008, 12:00:12 am »
You have to write your own generator through the API as I did. WSDL and XSD are not generated through this macro mechanism.
