Author Topic: EA Project maintains original VS solution when linked with MDG  (Read 15836 times)
zaknixon
If I try to use the same EA project file in multiple VS solutions, the EA project maintains the original link to the first project. So, if I try generating code for the 2nd project, it will dump it in the first's directory structure. Also, if I delete the first solution, and try to regenerate the code in the second solution, it tells  me to reload the first solution that was deleted.
Is there anyway to refresh the folder/solution reference ?
