Author Topic: Resource documents  (Read 7473 times)
Paul W
Resource documents
« on: June 02, 2008, 08:59:23 pm »
Are these supposed to record the values in all the Tabs in the RTF Template Editor because my documents are not holdingthe Advanced Tab settings.
I want to skip the root package and limit the Heading Levels, but this information is not being retained in the Resource document.
I've set up my template, generated a document on the required package and it looks ok, so I saved it as a resource document. When I auto-generate the resource document i get the root package reporting!!
Re: Resource documents
« Reply #1 on: June 03, 2008, 07:57:48 am »
If I understand correctly, those advanced options are properties of the templates themselves.  They can only be overridden for a single generate.  If you want to change the options on a default template you can make a copy of it, and use that instead.
That's not to say that a resource document couldn't, but I don't think they do.
Dermot
« Reply #2 on: June 03, 2008, 04:52:25 pm »
Hello Paul,
The Document Options can be set in two places:
 F8 | Advanced tab or Options  tab - changes to these are temporary for a run of a report.
or
 RTF editor: File | Document Options - Changes to this set is saved with the document as its default settings.
