Author Topic: Sort in search not working (beta02)  (Read 6220 times)
thomas.kilian
« on: March 06, 2008, 11:17:52 pm »
2 bugs:
1) the date is not sorted correctly. dd-mm-yyyy is sorted like a ddmmyyyy integer, not like yyyymmdd
2) once a column is marked sorted and the next search is done then the column still has the sort marker, but no sorting is done. Easy solution: remove the marker. Better solution: do the sort as shown. Additionally: there needs to be a no-sort option (e.g. 3 clicks for up-down-none)
Tried to submit via beta bug report but got an server error. Will try once again later (if I don't forget it).
Edit:Now it worked after a 'Please fill in fields' for no fields intermediate page ::)
« Last Edit: March 06, 2008, 11:20:30 pm by thomas.kilian »
Re: Sort in search not working (beta02)
« Reply #1 on: March 06, 2008, 11:47:00 pm »
Hopefully you also filed a bug report for the bug report...
thomas.kilian
« Reply #2 on: March 07, 2008, 07:23:34 pm »
Sparx:
Thank you for your email, we are aware of this issue and hope to have a
fix for an up coming build.
Description: Report View doesn't sort properly on the date column
RSherman
« Reply #3 on: June 12, 2008, 09:45:43 am »
Also note that sort on Phase filed (probably also other fields) is not in decimal number format - example 200 is seen as a larger value than 1000 due to the leading integer 2.
« Reply #4 on: June 12, 2008, 08:37:22 pm »
Phase is meant to be a free-form text field.
For example, one could have the "Analysis" and "Implementation" phases, which would sort before the "Testing" phase, but around the "Coding" phase.
