Author Topic: RTF report problem (external requirement type)  (Read 5830 times)
Robo
« on: June 18, 2008, 04:58:32 pm »
I have some problems during generation of RTF reports. If I try the following in the template:
external requirements>
{ElemExtRequirement.Name}{ElemExtRequirement.Type}
{ElemExtRequirement.Notes}
<external requirements
The field '{ElemExtRequirement.Type}' is replaced by 'Requirement'. I expected something like 'Safety' as selected in the properties dialog of the requirement. The other fields are replaced as expected.
I had a realization relationship of a component with a requirement. I am not sure if this has something to do with the issue mentioned in my last post (problems with realisation relationship) some days before.
Any help is welcome!
Re: RTF report problem (external requirement type)
« Reply #1 on: June 19, 2008, 08:29:54 am »
It looks like the {ElemExtRequirement.Type} is accessing the element type, which will always be 'Requirement' for requirements.  If I'm understanding you correctly, I think that the field you're after is in Stereotype.  So try {ElemExtRequirement.Stereotype} if that is available.
Robo
« Reply #2 on: June 19, 2008, 07:36:19 pm »
hm, it seems to work with the stereotype ...
I think it's a little bit confusing if I set Type 'Safety' in the requirement properties dialog and have to use the stereotype field in the template editor to receive the type of requirement.  :-?
Anyway, many thanks for the hint.
« Reply #3 on: June 20, 2008, 08:15:39 am »
I agree, it is a bit confusing.
What I guess is happening is that it is reusing the existing element substitutions, where {Elem.Type} could be Class, Actor, Requirement etc.
So the requirement type is something like a subtype, and often this is what a stereotype represents.
« Last Edit: June 20, 2008, 08:17:49 am by simonm »
