Author Topic: Generation sequence diagram cuts off method name  (Read 5114 times)
Rik A
« on: June 25, 2008, 04:54:51 pm »
When i generate a sequence diagram during a debug run the method name is being cut off/corrupted, resulting in classes which do not exist. For example:
Nucletron.SMX.ApplicationLayer.ProcessComponent.TableControl.RotateTableEccentric.Execute()
becomes in the Recorded history:
Nucletron.SMX.ApplicationLayer.ProcessComponent.TableControl.RotExecute.Execute()
I just upgraded to EA 7.1 which seem to cause this, because in 7.0 this problem didn't exist.
Is there a setting causing this? Or is the namespace just too long?
Re: Generation sequence diagram cuts off method na
« Reply #1 on: June 26, 2008, 08:26:54 am »
I don't know what's causing it, but I would recommend you send a bug report to sparx systems using the link at the bottom of this page.
