Author Topic: Sequence Diagram - Message Values not displayed  (Read 7017 times)
nzxhvr
« on: June 25, 2008, 07:37:37 am »
I have two objects in my sequence diagram with message
AudioRequest.Rq(int, int, int, int) being sent from A to B.  The message has 4 parametes in it.
The message Parameters: as listed in the message dialog box are:
RequesterSystem : Requester Location,RequestedAudioSource : Audio Source,RequesterPriority : Priority,ResourceRequestStatus : Allocated
There are no Parameter Values: defined in the dialog box.
I would like the sequence diagram to show the message with the parameters listed in it as such:
AudioRequest.Rq(RequesterSystem : Requester Location,RequestedAudioSource : Audio Source,RequesterPriority : Priority,ResourceRequestStatus : Allocated)
It use to work, but now it doesn't and all my SD show the message as such:
Does anybody now how to resolve this?  I have tried input the information several different ways and still can't get it to show up.
« Last Edit: June 27, 2008, 05:36:52 am by nzxhvr »
Re: Sequence Diagram - Message Values not displaye
« Reply #1 on: June 25, 2008, 08:13:41 am »
Open the properties of your sequence diagram.
Make sure that 'Show Parameter Detail' is set to 'Full Details'.  (On the Features tab.)
nzxhvr
« Reply #2 on: June 27, 2008, 05:35:06 am »
That option is set.
I am using Biuld 830.
I also get the following error when I close the message properties dialog box:
DAO.Field[3163]
The field is too small to accept the amount of data you attempted to add.  Try inserting or pasting less data.
Which field is it referring to, the Parameter Values field is empty and the Parameters: field has the following info :
« Reply #3 on: June 27, 2008, 06:48:51 am »
Can you send in a (compressed) example project to Sparx support? That would certainly help them to figure out the database error.
You should use the bug report page for registered users - I don't think the 'general' one lets you attach files. You'll find the correct page by following the link near the top of either the Registered Users page (which you'll find by clicking the link at the top of any forum page) or via the link above the 'general' bug report form.
