Author Topic: MDG Integration for Eclipse and Keyboard  (Read 3555 times)
tletsch
« on: July 04, 2008, 04:15:25 am »
I have installed "MDG Integration for Eclipse 3.0" on Eclipse 3.4 with EA 7.1.830 and it works fine so far.
But if I want to add an attribute to a class inside of a classdiagram with context-menu>Attributes... , I would like to use just only the mouse-button and the keyboard with right-mouse+'b', as it works in EA: unfortunately this does not seem to work in the MDG Integration for me.
Is this a problem with just my installation/configuration or is this a 'normal' behavior?
Thanks in advance
Thomas
Re: MDG Integration for Eclipse and Keyboard
« Reply #1 on: July 04, 2008, 04:31:28 am »
My guess - I really don't know for sure - is that this is a Java thing. I suspect that hot keys are not intercepted and passed to EA the same way as they are in Windows.
Perhaps there is a tweak you can make in your Windows emulator. Otherwise you might be out of luck.
[Hopefully someone out there will be able to contradict me, and enlighten us about some setting (or whatever) I've overlooked.]
