Author Topic: SVN Crash  (Read 6452 times)
Robson Silva
SVN Crash
« on: July 08, 2008, 06:50:36 am »
The EA use with Oracle and CVS without problems. Now we're trying to configure it for use in SQL Server and SVN.
The repository of SVN is set and go through the command line update and I can commit.
In EA, I can download the project via server connect with SQL Server. When do I create a mapping in the version control settings, using type Subversion, EA client's crash.
My EA version is 6.5.803, Professional.
Is there any configuration in the EA that I am not running?
Thanks in advance,
Robson
Re: SVN Crash
« Reply #1 on: July 08, 2008, 08:26:33 am »
I don't know.  But two points.  You're using quite an old version of EA, and there have been a number of improvements to SVN integration in that time.
Also, if you're experiencing a crash you would be best to directly contact sparx systems support about the issue.
