Author Topic: Build 831 moves diagram connectors and labels  (Read 6694 times)
Dorian Workman
« on: July 09, 2008, 04:41:37 am »
Noted on both Activity Diagrams and State Machines, as soon as you open a diagram in 831 the connectors are moved around, and zooming/unzooming the diagram compounds the issue.   :'(
Thanks.
« Last Edit: July 09, 2008, 04:41:55 am by dworkman »
<a href="http://www.linkedin.com/in/dorianworkman" ><img src="http://www.linkedin.com/img/webpromo/btn_liprofile_blue_80x15.gif" width="80" height="15" border="0" alt="View Dorian Workman
Re: Build 831 moves diagram connectors and labels
« Reply #1 on: July 09, 2008, 08:10:37 am »
I haven't seen the problem on any of the activity or state machine diagrams I've looked at.
If you haven't done so already, please send in a bug report to sparx systems as soon as possible, including either a model sample, or before and after screenshots.
Thomas Mercer-Hursh
  • Computing Integrity
« Reply #2 on: July 09, 2008, 08:22:30 am »
There was another thread lately about autolayout on open ... are you sure that isn't what is hitting you?
Dorian Workman
« Reply #3 on: July 09, 2008, 09:28:12 am »
Not sure... I just uninstalled 831 and reinstalled 830, and the problem went away.  Is there some new 831 feature that might be causing this?  Is "autolayout" a new 831 feature?
Thanks.
« Reply #4 on: July 09, 2008, 09:40:13 am »
I'm not aware of any change that could be causing your issue.  Can you send an XMI export of a package showing the problems to sparx systems support?  I'd like to get this fixed as soon as possible.
Thomas Mercer-Hursh
« Reply #5 on: July 09, 2008, 09:48:54 am »
Here is the thread in case you want to check settings.
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1215463912
« Reply #6 on: July 09, 2008, 09:53:08 am »
Thanks Thomas,
I'm not concerned about that thread as it is an optional behavior during reverse engineering, and the behavior hasn't changed for a number of builds.
As far as I know there is nothing that should cause a diagram layout to be changed when loading a diagram, and it sounds like a possible regression issue in build 831.
RealAlex
« Reply #7 on: July 11, 2008, 01:39:59 am »
In case this apports any additional information, when I open one Interaction diagram, when zooming it moves everything randomly, but when I open Sequence diagrams is is moved, not only the connectors (that begin nowhere and ends in a lifeline), but also the lifeline activation lines "dance" around, about an inch.
And it is not autolayout, because (as far as I know) autolayout does not work with Sequence diagrams ;)
« Reply #8 on: July 11, 2008, 08:19:57 am »
If possible, can you send an example?  I've tried but can't reproduce it so far.
