Author Topic: "Import Tests from Other Element" feature  (Read 10252 times)
Ricardo Guerra
« on: July 19, 2008, 12:31:49 am »
Hi there,
i have a bunch of test cases defined in the "Unit" tab of the "Testing" workspace (ALT+3 or View>Testing).
This test cases should have been defined in the "Acceptance" tab and im now i have to move them from one tab to the other.
Im following the documentation "Import tests from other element" procedure but nothing really happens (!).
Detailed Scenario:
- I have a "Use case" object marked with the "Test case" stereotype.
- This test case has 3 unit tests defined in the "Unit" tab of the Testing workspace.
- I want to "move" them to the "Acceptance" tab.
- In the "Acceptance" tab i select the option "Import tests from other element" from the context menu over the list.
- i select all the "Unit::tc1", "Unit::tc2", ...,"Unit::tcN" in "select items to import".
- in "import from another element" i select the test case from where i want to import (this should be optional as i want to import them from the same test case...)
- press ok
- no tc's are imported.
Any suggestion?
Thanks in advance!
Ricardo
Dermot
Re: "Import Tests from Other Element" fe
« Reply #1 on: July 21, 2008, 11:54:32 am »
I would suggest you send this through as a Feature Request  email: http://www.sparxsystems.com/support/feature_request.html and email Sparx Support as well.
I can pass on via the Support email a simple work around for this.
« Last Edit: July 21, 2008, 11:55:33 am by Dermot »
