Author Topic: Wrong Highlighting in Class by Operation Selection  (Read 7665 times)
Mirko Meier
  • Mirko Meier
« on: July 23, 2008, 12:43:38 am »
PreConditions:
By using reverse enginnering form .NET classes in EA the will be a Problem by highlighting the correct operation.
All properties are grouped by there stereotype.
The Problem:
By opening the Operations in ContextMenu of of a class, the Dialog to manipulate Operations will open. On select an operation in the Dialog, the index bases Opertaion in Class will be highlighted.
The Problem is, that the sorted operations are different from the sorted opertaion in the class.
« Last Edit: July 23, 2008, 12:45:14 am by mirkom76 »
Regards
Mirko Meier
Re: Wrong Highlighting in Class by Operation Selec
« Reply #1 on: July 23, 2008, 02:02:53 am »
Try changing the sort settings on the Tools | Options | Objects dialog. You'll want to work with Sort Features Alphabetically and the two Group <feature type> by Stereotype settings. These are at or near the bottom of the two columns of check boxes.
You might also want to ensure that Allow Free Sorting is checked in the Project Browser group on the Tools | Options | General page.
Mirko Meier
  • Mirko Meier
« Reply #2 on: July 23, 2008, 04:10:08 pm »
That is very helpful, thanks, But the bug already exists.
The Highlighting is no problem for me. I only want post the bug.
But to work around the problem your suggestion is a good "work around".
Regards
Mirko Meier
« Reply #3 on: July 23, 2008, 09:55:31 pm »
Please (also) send a bug report directly to Sparx. Click the Report a Bug link below the Support link near the bottom of any forum page.
If you are a registered user, then click the link above the bug report form. This will send you to an alternate bug report which will allow you to attach a compressed copy of your project. If you can provide that example it will help Sparx isolate the bug.
