Author Topic: Corrupted EA file  (Read 5471 times)
José
Corrupted EA file
« on: August 05, 2008, 07:13:26 pm »
I'm having a corruption with my EA project file. For an unknown reason it is seen as corrupted (no crash occured).
The project file is only used by myself (no multi-user).
I tried to use the "repair" feature of EA. However, it tells me that it does not apply to this object....
Whenever I try to open it, EA stop working. In the event log the following information is written:
Faulting application EA.exe, version 7.1.0.831, time stamp 0x486d5bb6, faulting module MSJET35.DLL, version 3.51.2723.0, time stamp 0x3720a1f8, exception code 0xc0000005, fault offset 0x00007f34, process id 0x1128, application start time 0x01c8f6d6f5a4fb04
 :'( My latest back up is older than 2 days....
Any help?
thanks,
José
Re: Corrupted EA file
« Reply #1 on: August 06, 2008, 10:17:36 am »
I suggest you send the EAP file to Sparx Support and someone should be able to rescue your model for you (and investigate the problem that caused it)...
José
« Reply #2 on: August 06, 2008, 04:53:15 pm »
Thanks for the tip.
I have emailed my corrupted file.
José
« Reply #3 on: August 06, 2008, 10:07:19 pm »
Please post back and let us know what the actual cause was, once you hear from Sparx.
Thanks much,
José
« Reply #4 on: August 08, 2008, 01:47:34 am »
I got back a file from the support. However, all classes were gone. In that sense, the recovery was not too successfull  :o
José
« Reply #5 on: August 08, 2008, 03:41:59 am »
Well, let's wait for stage two. Perhaps that will be better.
