Author Topic: UML Profile Tag values and feature visibility  (Read 4755 times)
titu
« on: August 21, 2008, 12:40:22 am »
I am a new user to this forum, though I have been using EA for some time now. I have the following queries:
1. How can I make the stereotype of a Port visible? By default, I can see it only in the Properties tab; but not on the diagram.
2. I have created a profile that also contains a tag for a stereotype. When I save the package as a profile and try to use it after importing, the Tag does not appear. How can this be solved?
3. This is related to #2. I edited the profile (.xml file) manually to add the tags with all the allowed values. The stereotype is used for UML Constraint. Unfortunately, there is again a visibility problem, because the Tag was not shown on the diagram. Could you please suggest a solution to this?
Thanks a lot.
