Author Topic: Reverse engineering C++: Virtual base class  (Read 5287 times)
Johan Pettersson
« on: August 29, 2008, 06:29:40 pm »
I try to import a C++ file containing the following:
class DerivedClass : virtual public BaseClass
When this is imported/reversed engineered I get an error saying that the "virtual" keyword is not understood in this context.
Does this mean that Enterprise Architect cannot reverse engineer code containing virtual base classes?
I use a trial of Enterprise Architect 7.1 (Corporate) on Windows XP (64bit).
Thanks in advance!
/Johan
« Last Edit: August 29, 2008, 06:53:10 pm by johan.pettersson »
Re: Reverse engineering C++: Virtual base class
« Reply #1 on: September 01, 2008, 08:17:26 am »
It can, and I just copied your example and it did.
There could be something else that's causing the problem, (eg. macros) if you file a support request with sparx systems providing some sample code they should be able to tell you what's going on.
Johan Pettersson
« Reply #2 on: September 01, 2008, 04:08:33 pm »
Thanks Simon!
Then I have probably misunderstood the problem some way. I'll look into it and get back either here or with a support request. Thanks again!
Johan Pettersson
« Reply #3 on: September 01, 2008, 06:23:12 pm »
Hi again,
I certainly misunderstood the problem. The reverse engineering process said:
Settings\johan.pettersson\Desktop\Assertions.h on line 59.  Unexpected symbol: virtual
You may need to define a language macro.
I didn't understand/didn't see the macro part but got stuck on the fact that it seemed to "blame" the virtual keyword in this context. I suppose this really is the case but it is actually a macro that is to blame for screwing up the context  :) The code I supplied was a simplified example (simplifed way to much of course!). It is really the following:
class AMACRO DerivedClass : virtual public BaseClass
The AMACRO screwed things up of course and when adding it to "Settings"->"Preprocessor Macros" it worked out fine.
Thanks for your help!
« Reply #4 on: September 01, 2008, 07:19:57 pm »
Hi again,
That's because the error message was misleading...  It could have read:
Settings\johan.pettersson\Desktop\Assertions.h on line 59.Unknown symbol: "AMACRO" before unexpected symbol: "virtual".
You may need to add a macro "AMACRO" for this language "AMACRO"
And been more helpful...
« Last Edit: September 01, 2008, 07:20:26 pm by PaoloFCantoni »
