Author Topic: RTF report for customSQL search results - fails  (Read 3884 times)
« on: September 23, 2008, 05:00:40 pm »
You're supposed to be able to generate an RTF report for selected items in a search.
Once the search generates output, you can select one or more of the items and then using the <Search Item Context Menu>|Documentation... generate the report.
When I select either of the options under Documentation... the RTF Generation dialog doesn't come up as it's supposed to.  Since I've previously had problems specific to my machine/environment; before I report a bug, can anyone confirm/deny that the dialogs do come up for them?
If the dialog does come up, are you able to generate a document successfully?
How are the results from the search linked to the document templates?  I've made the assumption - since i can't see it explicitly documented anywhere that I use the Element level fields in the template to map to the fields returned by the search.
BTW: setting up a Model Document (Virtual) - with search also has the generation fail - without any explanation (other than "Generation Failed").  I suspect for the same reason (that the dialog or API) doesn't come up.
<EDIT>
When I first posted, I forgot to mention I was using a custom SQL query to return the search list.
I've been able to generate RTF output for Query Builder searches.
But I am interested in using custom SQL searches...
</EDIT>
I'm using EA 7.1 (832) on Windows Server 2008 (64bit)
TIA,
« Last Edit: September 23, 2008, 06:37:37 pm by PaoloFCantoni »
Re: RTF report for customSQL search results - fail
« Reply #1 on: September 24, 2008, 08:12:18 am »
In order to use any EA functionality with a custom SQL search, you will need to return the guid and type of the object found.  This is described at http://www.sparxsystems.com.au/EAUserGuide/index.html?creating_filters.htm, although it doesn't explicitly mention reporting.
eg. SELECT ea_guid AS CLASSGUID, Object_Type AS CLASSTYPE, Name FROM t_object
It sounds like there is a user interface issue here that it isn't letting you know what's wrong though, so go on and report the bug.
« Reply #2 on: September 24, 2008, 11:58:11 am »
(My emphasis...)
Thanks Simon!
That did the trick...
Perhaps Roy could weave his magic and make this more prominent.  Also, the statement about a package list OR a search.  This stumped me for a while...
I'll pop a bug report in about the non-explicit dialog.
RoyC
  • Read The Help!
« Reply #3 on: September 24, 2008, 04:01:13 pm »
I have updated the Help in a number of places to highlight the point about SQL searches. Changes should be visible at the release of the next build.
Best Regards, Roy
