Author Topic: Fields order in RTF template  (Read 4273 times)
Jüri
« on: September 25, 2008, 04:59:36 pm »
Hi!
Is there any possibility to use custom order of fields in RTF template?
Current problem: I modified RTF template for UC scenarios.
I want that first will be scenarios and then internal/external requirements. Template editor does not allow to do that. Is there any possibility how do overcome it?
Thank you!
Jüri
Pkhaiat
  • If it ain't broke, don't fix it.
Re: Fields order in RTF template
« Reply #1 on: September 26, 2008, 02:06:59 am »
It is possible: select the section you want to move, & use the up / down hands at the top of the section frame to re-order them.
Jüri
« Reply #2 on: September 26, 2008, 03:30:01 pm »
thanks! yes, that the case. Problem is, that if you already have defined something, then uncheck this field, move to the other section of template and define again, EA crashes during document generation:(
Pkhaiat
« Reply #3 on: September 26, 2008, 10:21:32 pm »
Sparx is aware of this issue (this is but one of the many ways to crash EA using the RTF editor/generator). They have promised to fix many of these in the post 832 releases of EA.
In the meantime, you can try creating a new template, rearranging the sections, then adding the content. No guarantees, but it might work more often. ::)
