Author Topic: Removing elements when generating code  (Read 3413 times)
Rinaldo
« on: October 09, 2008, 02:07:13 am »
Hi.
I created a class on my EA project with one method and one attribute. Then I clicked the Generate Code option to create a file with my VB.NET code. All worked ok.
After that, I removed the attribute from my class on my EA project and generated the code again. The attribute was not removed from the generated code. I tried again, this time removing the method, bu the code keeps the method when is generated.
Is this by design? I think it should not be, since this way I can't trust this Generate Code option to create my classes. If I am right, this option only appends new elements to the code but does not remove old ones.
Can anyone confirms that behaviour?
Rinaldo
Rinaldo
Re: Removing elements when generating code
« Reply #1 on: October 09, 2008, 05:50:44 am »
Check your options regarding code synchronization. If tweaking these does not solve the problem then I suggest you submit a bug report to Sparx.
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: October 09, 2008, 06:09:56 am »
Hi Rinaldo,
If you enable the 'On forward synch, prompt to delete code features not in model' option, you can specify to delete the attributes.
t-kouno
t-kouno
