Author Topic: Size of (resized) Image Library objects not saved  (Read 4346 times)
oldschool
« on: October 08, 2008, 07:21:39 pm »
Suppose I use the 'Select Alternative Image' option and select an image from the Image Library, and then resize the object and save the diagram. I close the diagram and then re-open it. The object has reverted to its default size. Is there any way I can get it to save/persist the image size?
Re: Size of (resized) Image Library objects not sa
« Reply #1 on: October 09, 2008, 08:19:52 am »
What build of EA are you using?  I remember that happening at one stage, but it doesn't happen (for me) any longer.
oldschool
« Reply #2 on: October 09, 2008, 08:34:17 am »
I'm using version 7.0.815 (build 815). We have v7.1 at work as well - will my original licence work if I uninstall my current version and install v7.1 (if that would fix the problem)?
« Reply #3 on: October 10, 2008, 09:49:54 am »
Well, I don't know if your licenses are all kept up to date, but the license would work and it should fix the problem.
oldschool
« Reply #4 on: October 10, 2008, 06:04:53 pm »
Thank you - upgrading did indeed fix the bug.
