Author Topic: ODBC Reverse engineering problem (Access / Excel)  (Read 4766 times)
tsaltd
« on: September 18, 2008, 01:11:59 am »
… I cannot reverse engineer Access tables and Excel spreadsheets into Classes in context of Data Modeling diagram  (Excel wks was created by exporting the Access tables ).
I get the following errors …..
Excel worksheet .xls  (ODBC Driver specifies Excel 2000 - 3 ) ....
"ODBC Driver Manager does not support the Function"
Access Table -- .mdb (
"Unrecognized Database Format"
Error dialog windows both have "EA" title and are modal over parent "Reverse Engineering Progress" / "Current Action"
Both of these data sources open correctly using MS Query ODBC connection.
EA version is 7.1.830 ... single user version ( DB version 4.01)
hope this is enough info to get response from someone who has run into this before ... and may have a fix.
Steve
joneil
Re: ODBC Reverse engineering problem (Access / Exc
« Reply #1 on: October 15, 2008, 02:55:22 am »
I am running into the same problem, doesn't look like you got any response back yet.  Have you come up with anything as a work around?
Joe
hd
« Reply #2 on: October 15, 2008, 08:11:09 am »
Go to ... Tools | Options and check Use JET 4.0 to import Access 2000/2003 database objects.
joneil
« Reply #3 on: October 15, 2008, 08:31:42 am »
I am getting an error message "Database cannot be opened". There is not security on this database and I am able to open it without a problem through Access and I have made sure that I do not have the database open in Access prior to attempting the import.
Any suggestions?
Joe
