Author Topic: No transparency on imported object image  (Read 3989 times)
Emilio
« on: October 15, 2008, 10:51:48 pm »
There are some ocasions when I am making a design that I need to change the appearance of an object.
I select the object and choose the Change Appearance and then import an image. The image that would replace it is a GIF with transparency but when it is imported into EA the image appears with an annoying white background that contrasts heavily with the diagram's background color.
This looks like an eye sore on any diagram.
Re: No transparency on imported object image
« Reply #1 on: October 15, 2008, 11:01:38 pm »
Hi Emilio.
What I meant in the other thread where you posted this, was that you make a bug report directly to Sparx. That is as an alternative to a post here, which is a user forum. The Sparxians are very active participants here, but these posts do not (necessarily) go into the queue for consideration at Sparx.
Once again, follow the links I mentioned in the other post to get to the correct report forms.
