Author Topic: RTF generation and  connector.valueOf  (Read 3546 times)
Robert Preddy
« on: October 24, 2008, 09:44:45 pm »
If I place this code into a RTF template (derived from the basic template):
{Connector.valueOf(ConnectorAltName)}
inside table inside the connector> section (just below the {Connector.Name} then when you attempt to generate the report EA crashes.
EA version is 7.1.828 unicode.
« Last Edit: October 24, 2008, 09:46:32 pm by robbyp1 »
Oliver F.
    • Karl Storz homepage
Re: RTF generation and  connector.valueOf
« Reply #1 on: October 24, 2008, 10:36:21 pm »
I did not reproduce this behavior but I suggest to retry this with the latest EA build (833) and if it still occurs then file a bug report.
Changes are applied frequently and chances are not bad that it has been fixed in the meantime.
Good luck.
Oliver
