Author Topic: I can't control menu state in Python  (Read 9562 times)
goshawk
« on: November 22, 2005, 09:52:05 pm »
Hi there :D
I'm writing add-in code for EA 4.50.744 (Unicode) in Python.
I want to control the menu state (selectable or not) by EA_GetMenuState, but I can't.
# I attach my code at the end of this mail
In this code, I define 1 parent menu "AAA" and 2 child  menus "BBB", "CCC". I expect that menu "AAA" and "BBB" are selectable, "CCC" is not.
But, all the menus are selectable. Why? ???
Is there any example that control menu state in Python?
My envirronment
OS  Windows XP SP1
Python 2.4.1
wxPython wx-2.5.5-msw-unicode
import sys
from win32com.server.util import wrap, unwrap
import win32com.client
import wx
# For defaultencoding
if hasattr(sys,"setdefaultencoding"):
   sys.setdefaultencoding("shift_jis")
# For Late Bound
from win32com.client import dynamic
# For debug
debugging = 0
if debugging:
   from win32com.server.dispatcher import DefaultDebugDispatcher
   useDispatcher = DefaultDebugDispatcher
else:
   useDispatcher = None
class TestPlugIn(wx.App):
   _public_methods_ = [ 'EA_MenuClick',
                        'EA_GetMenuItems',
                        'EA_GetMenuState',
   _reg_progid_ = "PythonUtil.TestPlugIn"
   # >>> import pythoncom
   # >>> print pythoncom.CreateGuid()
   _reg_clsid_ = "{3DBD5A66-CCBC-4545-85FE-784F99A4CE94}"
   # Menu items
   def EA_GetMenuItems(self, Repository, MenuLocation, MenuName):
       if MenuName == "":
           menu = [
               u'-&AAA',                ]
       elif MenuName == u'-&AAA':
           menu = [
               u'&BBB',
               u'&CCC',
       return menu
   # Menu state control
   def EA_GetMenuState(self, Repository, MenuLocation, MenuName,
                       ItemName, IsEnabled, IsChecked):
##        print "EA_GetMenuState"
       if MenuLocation == "TreeView":
           IsEnabled = False
       elif MenuLocation == "Diagram":
           IsEnabled = False
       elif  MenuLocation == "MainMenu":
               IsEnabled = True
               if ItemName == u'&BBB':
                   IsEnabled = True
               else:
                   IsEnabled = False
       print MenuName, ItemName, IsEnabled
   def EA_MenuClick(self, Repository, MenuLocation, MenuName, ItemName):
       print "No choice"
def main():
   print "TestPlugin ver", version
   app = TestPlugIn(0)
   app.MainLoop()
if __name__ == '__main__':
   if len(sys.argv) < 2:
       main()
   else:
       import win32com.server.register
       if sys.argv[1] == "--register":
           print "regist COM server"
           win32com.server.register.UseCommandLine(TestPlugIn,
                                                   debug=debugging)
       elif sys.argv[1] == "--unregister":
           print "Unregist COM server"
           win32com.server.register.UseCommandLine(TestPlugIn)
       else:
           print "Usage: testplugin.py [--register|--unregister]"
Re: I can't control menu state in Python
« Reply #1 on: November 22, 2005, 11:44:36 pm »
Maybe because MenuLocation can take only "TreeView" and "Diagram"? I never came across "MainMenu" ???
Aaron B
« Reply #2 on: November 23, 2005, 04:41:17 pm »
"MainMenu" is indeed a valid location.
My only initial thought is to make sure your indentation/logic is correct.  It is a bit hard to tell from your pasted sample as the spacing seems to be out.
Just to try a different logic flow, perhaps try this:
 IsEnabled = True
 if MenuName == u'-&AAA' and ItemName == u'&CCC':
   IsEnabled = False
Should result in all menu items except "CCC" being enabled.
goshawk
« Reply #3 on: November 23, 2005, 10:07:09 pm »
Hello! thomaskilian and AaronB.
Thank you for reply. :)
From Posted by: AaronB
Posted on: Today at 4:41pm
Sorry, I should use a tag for code.
Code:
  IsEnabled = True
    IsEnabled = False
I modified code as follows,
#!python
# -*- coding: shift_jis -*-
# testplugin.py
version = "0.01"
import sys
import wx
# For Late Bound
# For debug
debugging = 0
if debugging:
else:
   'EA_MenuClick',
   'EA_GetMenuItems',
   'EA_GetMenuState',
 _reg_clsid_ = "{EE11FD80-F4D2-4DE1-9F9E-01838711405A}"
 # Menu items
   if MenuName == "":
     menu = [
       u'-&AAA',      ]
       menu = [
         u'&BBB',          u'&CCC',
   return menu
 def EA_GetMenuState(self, Repository, MenuLocation, MenuName, ItemName, IsEnabled, IsChecked):
     IsEnabled = False
     IsEnabled = False
     IsEnabled = True
     if (MenuName == u'-&AAA') and (ItemName == u'&CCC'):
       IsEnabled = False
   print "No choice"
def main():
 app = TestPlugIn(0)
 app.MainLoop()
   main()
 else:
     win32com.server.register.UseCommandLine(TestPlugIn, debug=debugging)
   else:
:-[ I can't control indentation.
I tried modified code, but still all the menu were selectable.
Then got debug print messages as follows,
-&AAA &BBB True
-&AAA &CCC False
-&AAA &BBB True
-&AAA &CCC False
-&AAA &BBB True
-&AAA &CCC False
-&AAA &BBB True
-&AAA &CCC False
-&AAA &BBB True
-&AAA &CCC False
valiable IsEnabled was actually set "False", but menu "CCC" was still selectable.
Did anyone control menu state in Python? :-[
Thank you.
« Reply #4 on: November 24, 2005, 12:59:38 am »
Okay. So my suggestion would be to reduce the example to a single entry and trying to toggle that on/off. Having that working it should be possible to crawl back to your original code  :P
goshawk
« Reply #5 on: November 24, 2005, 04:11:35 am »
Hi  thomaskilian
Thanks for your advice.
I minimized my code. It has only one menu "AAA".
Then menu "AAA" will be always unselectable(IsEnabled = False).
#!python
# testplugin2.py
version = "0.01"
import sys
import wx
# For Late Bound
# For debug
debugging = 0
if debugging:
else:
       'EA_MenuClick',
       'EA_GetMenuItems',
       'EA_GetMenuState',
   # Menu items
       if MenuName == "":
           menu = [
               u'&AAA',                ]
       elif MenuName == u'&AAA':
           menu = [                ]
       return menu
           IsEnabled = False
           IsEnabled = False
           IsEnabled = False
               IsEnabled = False
       print "No choice"
def main():
   app = TestPlugIn(0)
   app.MainLoop()
       main()
   else:
                                                   debug=debugging)
       else:
I tried above code, but the menu "AAA" is selectable.
So, debug print is as follows,
&AAA False
&AAA False
&AAA False
&AAA False
&AAA False
&AAA False
No choice
Sigh... :-/
« Reply #6 on: November 24, 2005, 05:03:07 am »
I now tried this with Perl and - no matter what I set isSelected or isEnabled - the entries always appear and are selectable. Looks like a bug. I didn't come across since I simply included menu items or left them out. That still is okay for me, but EA_GetMenuState doesn't seem to work correctly.
« Reply #7 on: November 24, 2005, 01:29:31 pm »
EA_GetMenuState seems to work for me, but I'm not using Python (or Perl).  The possibility that occurs to me is that maybe you haven't declared your functions to have those parameters passed by reference.
I had a bit of a look for how to do this in python and came up with the following page.  Hope it helps http://mail.python.org/pipermail/python-win32/2002-November/000590.html
goshawk
« Reply #8 on: November 24, 2005, 08:51:26 pm »
Hello simonm
Thank you for your importtant advice.
I refered that webpage. That's it.
I added code "return 0, IsEnabled, IsChecked" to method EA_GetMenuState for reference values.
#!python
# testplugin2.py
version = "0.01"
import sys
import wx
# For Late Bound
# For debug
debugging = 0
if debugging:
else:
       'EA_MenuClick',
       'EA_GetMenuItems',
       'EA_GetMenuState',
   # Menu items
       if MenuName == "":
           menu = [
               u'&AAA',                ]
           menu = [                ]
       return menu
           IsEnabled = False
           IsEnabled = False
           IsEnabled = False
               IsEnabled = False
       print "No choice"
def main():
   app = TestPlugIn(0)
   app.MainLoop()
       main()
   else:
                                                   debug=debugging)
       else:
I could control the menu state.
In this code, the menu "AAA" is unselectable. I got it!
Thank youf so much, everyone.
« Reply #9 on: November 25, 2005, 12:33:07 am »
Unfortunately there is no such construct for Perl :'( So one can't actually make use of that feature. By default Perl->Perl uses always by-reference, but the COM interface seems to behave somewhat different.
goshawk
« Reply #10 on: November 28, 2005, 05:28:07 am »
Hi there, I have a problem again.
I added two more sub menus "BBB", "CCC" to EA_GetMenuItems.
I also added the method "SomeMethod" and call in EA_MenuClick at the menu "BBB".
   # Menu items
       if MenuName == "":
           menu = [
               u'-AAA',                ]
       elif MenuName == u'-AAA':
           menu = [
               u'BBB',
               u'CCC',
       else:
           menu = ""
       return menu
           IsEnabled = False
           IsEnabled = False
           IsEnabled = True
           if (MenuName == u'-AAA') and (ItemName == u'BBB'):
               IsEnabled = True
           elif (MenuName == u'-AAA') and (ItemName == u'CCC'):
               IsEnabled = False
       print "EA_MenuClick"
           pass
           pass
               print "Selected", MenuName, ItemName
               self.SomeMethod()
       return 0
   def SomeMethod(self):
       print "Do something"
I executed this code form EA. Then I got the debug print as follows,
-AAA BBB True
-AAA CCC False
-AAA BBB True
-AAA CCC False
-AAA CCC False
-AAA BBB True
-AAA BBB True
EA_MenuClick
Selected -AAA BBB
Do something
I could executed the method "SomeMethod" as I expected.
Next, I added one more menu "DDD". This menu is not a sub menu as "BBB" and "CCC".
       if MenuName == "":
           menu = [
               u'-AAA',
               u'DDD',
           menu = [
               u'BBB',
               u'CCC',
       else:
           menu = ""
       return menu
           IsEnabled = False
           IsEnabled = False
           IsEnabled = True
               IsEnabled = True
               IsEnabled = False
           elif ItemName == u'DDD':
               IsEnabled = False
           pass
           pass
               self.SomeMethod()
       return 0
So, I tried this code again.
But I couldn't execute the method "SomeMthod".
I got debug print as follows,
DDD False
DDD False
DDD False
DDD False
-AAA BBB True
-AAA CCC False
DDD False
-AAA BBB True
-AAA CCC False
DDD False
DDD False
-AAA BBB True
-AAA BBB False
Why is IsEnabled "False" when I chose the menu "BBB"?
Why can't I execute the method "SomeMethod"?
Is there any advice or suggestion?
thank you.
