Author Topic: Build 833 HTML help may be out of date  (Read 8990 times)
« on: November 22, 2008, 11:36:47 pm »
The compiled HTML (CHM) file for Build 833 shows a perplexing compile date. My copy shows a file date of 2008-10-22 (which is probably when I downloaded it to my system), but the index tells me it was compiled on 2008-08-08. This would seem like an earlier build, sometime around 831. The Windows file properties dialog gives a file creation date of 2008-09-14.
The file may be out of date, or the compiled date might not have been changed.
This applies to the stand-alone help file from the Registered Users download page. Note that I have not checked whether the same issue applies to the help file delivered as part of the full install kit. [I do not want to get my configuration straddling two versions if there is a problem.]
I have reported this issue to Sparx.
RoyC
  • Read The Help!
Re: Build 833 HTML help may be out of date
« Reply #1 on: November 24, 2008, 11:20:16 am »
The compile date in the index for the Help released on October 22nd was not updated, but the content of the Help was accurate. On October 28th, the whole set of Help files on the Registered Users page was flushed through, and the index date is actually October 28th. The content, however still pertains to Build 833.
If you have concerns about the version of the Help you are using, check the contents list. For Build 833, it has sections called Visual Execution Analyzer and Enterprise Architect Reports. In earlier builds, these sections were called Debug and Profile and Creating Documentation respectively.
Sorry for the confusion.
Best Regards, Roy
