Author Topic: API Attribute::StereotypeEx() behavior unexpected.  (Read 3983 times)
johnm9
« on: November 28, 2008, 03:07:29 pm »
On Version 833.
I'm trying to change the stereotype of an Attribute from "Attribute" to "XSDAttribute" with the following VBA code:
  Set att = ele.Attributes.GetAt(i - 1)
               If att.StereotypeEx = "Attribute" Then
                   att.StereotypeEx = "XSDAttribute"
                   att.Update
  End If
However, the result is <<XSDAttribute, Attribute>>. It ends up that one more stereotype is added instead of changing it.
I've tried to use "att.Stereotype" instead of "att.StereotypeEX" but no luck.
Re: API Attribute::StereotypeEx() behavior unexpec
« Reply #1 on: November 28, 2008, 03:37:02 pm »
Hi John,
Based on the behaviour of EA's UI (Unique Interface) you'll have to delete the primary stereotype and then add the new one.  The multiple stereotypes management in EA is only barely serviceable.
You will also (if you plan to write defensive code), probably need to read in all the StereotypeEx And Stereotype, sort out what you want to retain and then kill both and set both in the right order (making sure that the first stereotype in StereotypeEx is the primary).
