Author Topic: Delete "Feature" on diagram - silently purges  (Read 3459 times)
« on: November 28, 2008, 06:57:27 pm »
If you accidentally have a feature selected on a diagram and press the delete key, the feature is silently purged from the model.
This needs to rectified immediately!
A user, while trying to remove a vertex from a diagram, may accidentally create a "click too far" and accidentally have selected a feature rather then the encompassing vertex.  So far I've done it 5 times this week, and fortunately noticed EA had purged the feature and reverted to my backup.  But in other circumstances this could go unnoticed for a long period of time.
Any purging of items from the repository should be failsafed.
Consistency, Consistency, Consistency! TM
Oliver F.
  • ArenĀ“t we all in the model business ?
    • Karl Storz homepage
Re: Delete "Feature" on diagram - silently purges
« Reply #1 on: November 28, 2008, 08:40:22 pm »
To be honest I never had this before. To remove anything from the model I have to explicitely press the Ctrl-Key and in any case I get a warning dialog.
A lot of our coworkers here have created several orphans that way because they expected eg. the element notes to be removed after using the Del-Key while indeed they are not- on the other hand there is no notes element visible in the project browser to be seen and the notes can only be regathered with a search *sigh*
Consistency, Consistency, Consistency! TM  :P
However if you are correct I believe it might affect certain element types only because all of those I am working with do not show this behavior. In any case this is worth a critical bug report.
Oliver
