Author Topic: UI Problem with XSDElement MaxOccurs  (Read 3967 times)
« on: December 03, 2008, 06:28:01 pm »
There is a UI problem for XSD Elements.  When you reverse engineer an XSD, it will correctly set the maxOccurs:unbounded to MaxOccurs: * for the XSDElement.  Thus the MaxOccurs (Multiplicity Upper Bound) reads * and the Tagged Value maxOccurs reads unbounded.
If you change the MaxOccurs to (say) 6, EA correctly changes the Multiplicity Upper Bound to:6 and the maxOccurs Tagged Value to: 6.
If you change the MaxOccurs back to *, EA incorrectly sets the MaxOccurs (Multiplicity Upper Bound) to: -1 which makes the Tagged Value read -1.  This is incorrect.
Repoprted,
