Author Topic: UI creates different XSD Tagged Values from RE  (Read 3312 times)
« on: December 03, 2008, 06:51:20 pm »
When you reverse engineer an XSD, and then update a value (such as MaxOccurs - as in the UI problem with XSDElement MaxOccurs bug report), an additional set of properties with default values are created by the UI within the tagged value set for that element (including: anonymousRole, form, default, fixed)
The reverse engineering process should create these values also OR the UI should not create them, since they are defaults.
Consistency, Consistency, Consistency! TM
Reported,
