Author Topic: Default Initial Value dialog doesn't wrap text  (Read 4539 times)
« on: December 12, 2008, 05:02:08 pm »
For long values of the initial value the builder[1] engaged control dialog (Captioned: Default Initial Value), doesn't wrap.  So, not withstanding the control takes up a significant area of the screen, you only see part of one line (unless you put in explicit hard returns).
Since the field is a memo field, it should wrap - like other memo fields.  We acknowledge that in the associated text box this isn't possible, but the memo control should.  (also, if the text does overflow the text box, there should be the usual ellipsis to indicate more...).
Reported,
[1]Yes Simon, this time I DID spot the builder button ;)
