Author Topic: Trying to connect to a DBMS under Wine (MySQL ODBC  (Read 9155 times)
jsbueno
« on: December 19, 2008, 11:27:21 pm »
Hi there,
Some desktops in our enviromment use GNU/Linux. I am trying to get EA emulated under Wine to open projects stored in DBMS - I gave uop trying oracle because its client software is way overkill to try to get running under wine.
Nonethelss, i found no references on this forum, or in the docs, or on the Web about how to set up a working DBMS connection for EA under wine.
I am currently trying to use MySQL using ODBC (I did install native windows MDAC ODBC thigns, I amnot not trying the wine/unixODBC bridge). EA even connects to the DB but when it trioes to oopen a project I  get this error:
"ADODB.Fields item cannot be found in the collection corresponding to the requested name or ordinal"
I suspect this might be  due to some subtle data transformation (like e.g. line ending chars) that takes place when one does switch from reading the DB on Windows to Linux. I also hope this could be fixed by some paramter on the ODBC connection string.
Did anyone got this working (even with a very different setup)? Else, any ideas?
Re: Trying to connect to a DBMS under Wine (MySQL
« Reply #1 on: December 22, 2008, 08:18:33 am »
It sounds like the kind of error you get when you don't set the advanced options as documented at http://www.sparxsystems.com/uml_tool_guide/uml_model_management/setupmysqlodbcdriver.html.
jsbueno
« Reply #2 on: December 22, 2008, 09:34:51 pm »
I had set the options as listed in there,
except by the fact that option (1)  "Don't Optimize Column Width" is marked as removed since version 3.51.18. -  I am trying to use version 5.01.0004 .
hd
« Reply #3 on: December 23, 2008, 08:17:44 am »
Stay with version 3.51 of MyODBC - version 5 has problems.
jsbueno
« Reply #4 on: December 24, 2008, 06:26:24 am »
I tried to downgrade to myodbc connector 3.51.14  (the newest 3.51 connector did not look safe, as the option needed for EA was removed on  version 3.51.18 - some _years_ ago ).
Now everything looks fine, but when I finally try to read a project from the datbase I get an alert box which simply states "Provider:[-2147418113]"
Any other ideas? I'd even like to simply hear of anyone who ever got a succesfull DBMS connection under a Wine emulated EA. - I've seen no references of it on this forum or on the web.
Sparxians: is there a way for me to at least get an error description besides the error number above?
Takeshi K
    • Sparx Systems Japan
« Reply #5 on: December 24, 2008, 02:57:32 pm »
Just for your information,
EA help says that MySQL ODBC 3.51.14 has problems so do not use the version.
See the 'MySQL ODBC Driver' page of the EA help file.
t-kouno
jsbueno
« Reply #6 on: December 24, 2008, 10:29:12 pm »
Oh..thanks --
I installed 3.51.14  because I remembered havign read something about it on the docs. Too bad it was exactly that it would not work.
Anyway, I did switch my version to 3.51.17 (it should be the last one usable since one of the advanced options needed by EA is gone from 3.51.18 and on) - and I get just the same error.
Merry Christmas to everyone, btw!
jsbueno
« Reply #7 on: December 31, 2008, 12:11:50 am »
Still no progress on this issue. I 've tried both 3.51.17 and 3.51.12 (listed in docs examples). None of them even got me as far as i got with the 5.1 series - I always getthe numeric error message instead of the mroe elaborate error I reported on the oppening of this topic.
I am still open to suggestions or ideas.
