Author Topic: Maintenance Workspace blocked, possibly bug?  (Read 3903 times)
Hans-Christian
« on: January 14, 2009, 09:51:52 pm »
Hi to all,
We are using EA build 834 and in our environment security is enabled and "Require User Lock to Edit", too.
I´m logging in as Administrator having ALL permissions. But it is not possible to add or modify any items in "Maintenance Workspace" (to bring up Alt+4). If security has been disabled it is possible  :-?
Is it a bug or intended?
Does anyone has an idea which permission should be the right one to set? Assuming something like "Manage Maintenance" but couldn´t be found in dialog.
For quick help which value to add in column "PermissionID" of table "T_SECPERMISSION" or "T_SECGROUPPERMISSION". Now values are going from 0 to 34.
any ideas?
/Hans-Christian
Re: Maintenance Workspace blocked, possibly bug?
« Reply #1 on: January 15, 2009, 08:24:51 am »
So, have you applied a user lock to the object you're trying to add or modify maintenance items for?
Hans-Christian
« Reply #2 on: January 15, 2009, 07:57:06 pm »
Hi Simon,
yes I applied a user lock. But the problem seems to be the update of the element in the tree view. You always have to to click an other object and then select back before you could add or modify any properties or adding e.g. any changes to the maintenance workspace after applying a user lock.
Now it works. Thanks.
/Hans-Christian
