Author Topic: Updating elements in shared packages  (Read 3636 times)
Truman303
« on: January 29, 2009, 10:11:30 pm »
Hello All
We have a number of EAP project files on a central server each of which is accessed by a number of people. Each .eap project typically contains the “Common” package (root node shared between projects) and a number of specialised (root node) packages containing diagrams which reference elements in the Common package. All packages are version controlled using Visual Source Safe.
I have noticed that when updating an element’s name (or moving a package) within the Common model, all references to that element in the current project will be updated however when opening a different project (also containing the Common model) all references to the changed elements have been removed from the specialised diagram.
The only way I can see this working properly is if we move all packages from every project into a “master” project and all changes to the common package must be made there so that all references are updated.
Any other suggestions? Is there another way to achieve this?
