Author Topic: EA 7.1 Build 834 DAO Database 3703 Error  (Read 3539 times)
Jeff Jones
« on: February 04, 2009, 07:21:36 am »
                I am using EA 7.1 Build 834 and when I open a project I get the following error. I was using 6.5 and I was getting the same error so I thought I needed to reinstall EA. I have searched your forums and Google but did not find any info on this error. Any help you could give me would be great.
Jeff Jones
Error
DAO.Database [3703]
Operation not supported on replicable databases that have not been converted to the current version
Re: EA 7.1 Build 834 DAO Database 3703 Error
« Reply #1 on: February 04, 2009, 07:26:39 am »
It sounds to me like:
  • You have EA set to use JET 4.
  • You've used eap file replication.
  • Your model itself is JET 3.5.
If you don't want to use JET 4, you could disable that option.
If you do want to, you'll probably need to disable the option anyway, remove replication then get the JET 4 base model.  At this stage you could set the JET 4 option back and do a database transfer of your model into that file.
