Author Topic: Adding tagged values to requirements  (Read 7318 times)
pH
« on: January 09, 2009, 04:37:04 pm »
I have lot of requirements that have around 10 tagged values. Its time consuming to attach all of them to individual requirements. Is there any smart way by which I can get the tagged values as default when I add a new requirement?
pH
<a href="http://webuml.org"><img src="http://webuml.org/images/webuml-badge.png" alt="Set UML Free!" style="border-width:0"></a>
Oliver F.
    • Karl Storz homepage
Re: Adding tagged values to requirements
« Reply #1 on: January 09, 2009, 06:58:40 pm »
Yes. Take a look at stereotyped elements in UML profiles.
This lets you create eg. a stereotyped requirements element which already holds a set of tagged values upon creation including default values if you want to.
Oliver
pH
« Reply #2 on: January 09, 2009, 08:39:50 pm »
Thanks for the reply.I am trying your proposed solution. Since I am not very familiar to EA, if you have more detailed steps / info please do share.
pH
Oliver F.
« Reply #3 on: January 10, 2009, 12:15:15 am »
I suggest you make yourself familiar with the process of creating a UML profile with stereotypes. The online help is a rather good source of information.
Basically what you have to do is create a stereotype for requirement elements and associate attributes to it. Afterwards you save it as a UML Profile and deploy it in a MDG technology.
This will create a new stereotyped requirements element which you can drop from your toolbox in the diagrams. All attributes you have associated in the profile will then appear as tagged values.
This sounds a bit strange at a first glance but it includes the keywords you need to look up: MDG technology, UML profile, stereotype and tagged values. Once you get familiar with the terminology you will get a better understanding of what this strange guy is trying to tell you  8-)
Oliver
Dermot
« Reply #4 on: January 12, 2009, 11:58:36 am »
The whitepaper on Requirements Management covers this process in detail specificaly for requirements "Attributes" - see: http://www.sparxsystems.com.au/resources/whitepapers/index.html
pH
« Reply #5 on: January 13, 2009, 01:01:50 am »
Thanks to both of you for your replies. Its working for me.
But there is one exception. When tagged value has enumeration how do we define it as an attribute ? Attribute doesnt allow for multiple values.
What I tried was, I created  a tagged value for stereotype im my UML Profile hoping that it automatically gets applied to the all elements of that type. But it didnt.
Thanks again,
pH
Oliver F.
« Reply #6 on: January 13, 2009, 01:35:44 am »
In your profile create a new class of stereotype "enumeration", name it as you like (here: A). Add each enumeration item as eg. a string attribute.
The stereotype B which is planned to use the enumeration needs an attribute of type "A" (as named above) with an arbitrary name (here: C), give it an initial value.
Save all as a profile.
Afterwards if you create a new element of type B you should be able to see a tagged value C which lets you choose between the elements as defined in the enumeration A.
Oliver
pH
« Reply #7 on: January 13, 2009, 04:02:52 pm »
It's Perfect!! . Thank you.
pH
friehmaen
« Reply #8 on: February 05, 2009, 12:32:56 am »
Worked fine with a requirement, but does this work for all other elements, too?
I tried to set up a stereotyped master document, which has about 10 predefined tagged values. But i didn't get it.
Thanks and Regards,
khr
