Author Topic: Frame around included UML diagrams  (Read 6553 times)
akede
« on: February 11, 2009, 09:35:47 pm »
Including a second UML diagram by using the feature "drop diagram as: diagram frame" is a great concept.
I have the issue that all of these frames however do not keep their proportions (size) after I change the default size (to smaller). I verified that the included diagram is the size I want and as long as I keep the diagram open all is fine. After closing and reopening again the diagram frame is changed again :-(.
Cheers
Alex
Alex
Think Network GmbH, Munich Germany
http://www.thinknetwork.com
TomO
  • EA - Bridging the gap between Business and IT
    • Sparx Systems
Re: Frame around included UML diagrams
« Reply #1 on: February 12, 2009, 12:37:59 pm »
Hello akede,
After the resize of the diagram frame if you click the save button, close then reopen your diagram you will find your changes are persistent.
I hope this helps.
