Author Topic: Use Case Stereotype Not Shown / Not Visable  (Read 3580 times)
Brian Hayes
« on: February 24, 2009, 05:32:30 am »
I've added a stereotype ("Business Use Case") to a use case and the stereotype label (e.g. "<<Business Use Case>>") does not show up in the diagrams.  Does anyone know how to make this happen?
I have stereotype visability enabled (as far as I can tell).  In the Use Case Diagram properties
Elements tab:
   + Use Stereotype Icons is checked
   + Show Element Stereotypes is checked
Features tab:
   + Show Stereotypes is checked
Enterprise Architect version 7.1.832
Thanks in advance for any help,
Brian
Re: Use Case Stereotype Not Shown / Not Visable
« Reply #1 on: February 24, 2009, 09:07:48 am »
«business use case» is a bit of a special case. It causes the use case to be drawn differently (diagonal line in the bottom right corner) but the stereotype won't be visible. If you need the text to show, you could try something slightly different, e.g. «businessUseCase» or even just «business».
